M172 Modbus serial master
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • M172 Modbus serial master
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
POPE3909
POPE3909
Explorer
Posted: ‎2023-05-09 11:47 PM
2787
Hi Guys,
I'm trying to read modbus registers with M172 as a master by following the below instructions:
Training M172 - M9.3 Modbus Serial Master - YouTube
I am getting '2' as output which is not part of what is described in object properties. I tried clicking the function block in case it shows the source code but no luck.
What does '2' means in this case? Could you please provide a direction where I can find more information?
Thank You.
  • Connectivity
Bastian_Schmitz
Champion
Posted: ‎2023-05-10 12:10 AM
I´m not sure but I expect this is a illegal address error. Did you try to increase/decrease the start address with 1?
Replies 6
Bastian_Schmitz
Champion
LeTomas
LeTomas Mentor
Mentor
Posted: ‎2023-05-10 12:12 AM
Hi @POPE3909 ,
If we follow the object properties for the "sysMbMTCP_FCxx" it looks like that the number 2 means "Exception code illegal data address" but i am not 100% sure if it is that in your case.
Best regards,
LeTomas
POPE3909
POPE3909
Explorer
Posted: ‎2023-05-10 12:17 AM
2776
Hi Guys,
Thank for your replies. Yes, I was reading the incorrect address. I changed to the correct address and it is all good now.
But I still want to know where/how to check the object properties? In the software, it only shows the following:
No mention of '2'?
LeTomas
LeTomas Mentor
Mentor
Posted: ‎2023-05-10 12:28 AM
In response to POPE3909
Hi @POPE3909 ,
I just checked the other blocks from ModbusTCP instead of serial:
BR
LeTomas
Bastian_Schmitz
Champion
Posted: ‎2023-05-10 01:01 AM
Hi Pope3909,
it seems there is space to increase the detail on the description.
The response which is fully described on the newer Modbus TCP functions is identical to the standart modbus response which you could find here Link
POPE3909
POPE3909
Explorer
Posted: ‎2023-05-10 04:06 PM
Thanks guys. đź™Ź
