Posted: 2019-06-03 07:20 PM . Last Modified: 2020-09-10 12:57 AM
Hi all,
I have a problem when I refresh page to read parameter of TM172, but it fail.
Who can help me ?
Thanks for watching
Posted: 2019-06-13 03:19 AM
Hello ,
Please raise a bfo case with program backup and the firmware of the M172P , As this not a known issue and we have to check and analyis the same.
Best Regards
Posted: 2022-06-22 01:38 AM
Hello the register address 20048 is in the range of the standard EEPROM values.
The EEPROM values on TM172 could be in the range of 16384...20479.
Please check if you have values in this range and check which typ you have defined.
Maybe this could help to anayse the problem.
Additional an information about the used ESME HVAC Version and BIOS Version could be helpfull.
Posted: 2022-07-04 10:34 PM . Last Modified: 2022-07-05 09:13 PM
I am facing same issue I don't know what to do will you guys help me to solve
Posted: 2022-07-04 10:38 PM
It is still necassary to knwo the target version which you select in your application, and to know which version is on the controller. Furthermore it would be important to know if you have EEPROM values in the range which generate the error.
WIthout this information it will be hard to solve the problem.
Posted: 2023-05-06 01:15 AM
I read this article. I think You put a great deal of exertion to make this article. I like your work.
