BACnet_Addons library - variable 'xEN' breaks case sensitivity
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • BACnet_Addons library - variable 'xEN' breaks case sensitivity
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
obscuresc
obscuresc
Troubleshooter
Posted: ‎2023-05-01 09:40 PM
1450
Hi all,
I'm using v2.4.0 of the BACnet Addons library from Toolbox
Variable 'xEn' seems to use the wrong case in each of the RelDef function blocks for all object types in library.
Spoiler
BACnet_RelDef_MV_link_ui(73) - error A4097: xEN => Object not found
BACnet_RelDef_MV_link_udi(73) - error A4097: xEN => Object not found
BACnet_RelDef_MV_link_r(73) - error A4097: xEN => Object not found
BACnet_RelDef_MV_link_i(73) - error A4097: xEN => Object not found
BACnet_RelDef_BV_link_x(71) - error A4097: xEN => Object not found
BACnet_RelDef_AV_link_ui(73) - error A4097: xEN => Object not found
BACnet_RelDef_AV_link_r(73) - error A4097: xEN => Object not found
BACnet_RelDef_AV_link_i(73) - error A4097: xEN => Object not found
BACnet_RelDef_MV_link_usi(74) - error A4097: xEN => Object not found
I'm not sure if there any other issues in other functions/blocks of the BACnet libraries, but could the library be updated to fix case-sensitivity?
Jack
  • HVAC
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2023-05-02 01:31 AM
In response to FedericoM
try this updated version...
BACnet_Addons_2.4.1.zip
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2023-05-01 11:38 PM
1443
I'll fix it in the next update.
Federico
FedericoM
FedericoM Mentor
Mentor
obscuresc
obscuresc
Troubleshooter
Posted: ‎2023-05-02 10:47 PM
Hi Frederico,
Thanks for the updated version.
Jack
