Keyboard shortcuts
ITA desktop client
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Working in the ITA desktop client
  • Keyboard shortcuts
  • Mark as Read
  • Navigation
  • ITA toolbar
  • Working with the Power Path Layout
  • What happens when multiple users work simultaneous...
  • Showing or hiding room overlays
  • Reviewing system preferences
  • Optimizing the design by following the recommendat...
  • Monitoring operations in Map View
  • IT Advisor desktop client
  • How to make Asset UIDs visible in the desktop clie...
  • Exploring the infrastructure in Map, Floor and Rac...
  • Configuring the PUE DCiE
  • The look and feel of the ITA desktop client
  • Navigation
  • ITA toolbar
EcoStruxure IT Support
Request Support
Back to ITA desktop client
  • Mark as Read
Keyboard shortcuts
Picard EcoStruxureIT
‎2019-11-06 07:13 AM
Keyboard shortcuts
Selecting
Key Item Action
Primary click Single item Select a single item
Ctrl+click Multiple items Select multiple non-consecutive items
Shift+click Multiple items
Select multiple consecutive items
Alternative: You can also draw a box around multiple items
Copying and Pasting
Key Item Action
Ctrl+C Selection
Copy selected item(s)
If the selection includes multiple items, the coordinates will be preserved relative to each other.
Ctrl+V Selection
Paste selected item(s) at cursor position
Ctrl+X Selection
Cut
The selection is only marked for being cut, and not actually cut away from its position until you paste it in another position.
Navigating
Key Item Action
Single-click Rack in floor layout Open the rack in rack layout
Double-click
Rack in floor layout Open the rack in rack layout and open the Properties dialog box for the selected rack
Double-click  Item in the Navigation pane Highlight the selected item in the selected layout
Double-click  Server in the Navigation pane Open the rack in the rack layout with the server highlighted
Double-click Item in the Power Dependency view Highlight the selected item in the layout
Double-click  Room in the Navigation pane Open the room in the layout (same tab)
Ctrl+- Layout Zoom out
Ctrl++ Layout Zoom in
Ctrl+ Home Layout Zoom fit
Ctrl+K Selection Show selection in the Navigation pane
Ctrl+L Selection Show selection in the Layout
F7 Open the Genome Library
Alt+Enter Open Properties dialog box
Ctrl+N Open New Room dialog box
Editing
Key Item Action
Arrow Keys Selection
Move selection 1/16 of a floor tile in that direction
Hold to keep moving it.
Arrow Keys+Shift Selection
Move selection by 1 mm
Hold to keep moving it. Coordinate guides will appear.
ESC Selection Interrupt move and return selected item to start position
Ctrl+Shift+E
Execute Planned Change (IT Advisor: Change feature)
Ctrl+Shift+C
Cancel Planned Change (IT Advisor: Change feature)
Ctrl+S
Unsaved actions
Save
Ctrl+Z
Last action
Undo
Ctrl+Y Last action Redo
Ctrl+R Selection Rotate selected item by 45°
Ctrl+I Selection Flip selected item 180°
Shift+Delete
Selection
Mark the selection for deletion
Delete
Selection
Delete the selection
