IT Advisor desktop client
ITA desktop client
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Working in the ITA desktop client
  • IT Advisor desktop client
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to ITA desktop client
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-06 07:13 AM
IT Advisor creates a consolidated view of your data center's physical infrastructure. Display of real-time device monitoring data from external systems as well as advanced model design recommendations and placement advice all enable quick assessment and resolution of potential critical situations.You can use the Application bar to navigate between the main parts of the desktop client.
  • Operations for monitoring IT Advisors.
  • Planning for planning the data center design, including planning for changes to the rack layout.
  • Analytics for accessing analytics, such as status reports.
Before you can get started using the application, initial system setup is required, including user administration, license and server management, external system setup for device monitoring and alarm data. Some of these options are available in the web client, some in the desktop client. More...
When the system setup is ready, you can using the desktop client and start building the initial data center infrastructure and add to the inventory or import data to create a model in the application that represents the real-world physical infrastructure. More...
