How to make Asset UIDs visible in the desktop client user interface
ITA desktop client
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Working in the ITA desktop client
  • How to make Asset UIDs visible in the desktop client user interface
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to ITA desktop client
  • Mark as Read
Picard EcoStruxureIT
‎2021-10-25 07:05 PM
Asset UIDs are visible in the IT Advisor desktop client version 9.2.3 and newer under General Preferences and can be copied/pasted.
Note: The Asset UID field is read-only. You can select it, but you cannot modify it.
To activate this feature, edit the *.ini file of the desktop client. This is a local configuration, so each IT Advisor user must make this change.
Windows
  1. Go to C:\Program Files\EcoStruxure IT Advisor x.x.x\application.
  2. Open the EcoStruxure IT Advisor.ini file in a text editor, such as Notepad++.
  3. Add the following line:
    -DAsset.show.uuid=true
  4. Save the file.
  5. Restart the ITA desktop client if it is open.
MacOS
  1. Go to Applications and right click EcoStruxure IT Advisor.
  2. Go to Show Package Contents > Contents > /MacOS.
  3. Open the eclipse.ini file in a text editor.
  4. Add the following line:
  5. Save the file.
  6. Restart the ITA desktop client if it is open.
