ITA toolbar
ITA desktop client
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Working in the ITA desktop client
  • ITA toolbar
  • Mark as Read
  • Navigation
  • ITA toolbar
  • Working with the Power Path Layout
  • What happens when multiple users work simultaneous...
  • Showing or hiding room overlays
  • Reviewing system preferences
  • Optimizing the design by following the recommendat...
  • Monitoring operations in Map View
  • Keyboard shortcuts
  • IT Advisor desktop client
  • How to make Asset UIDs visible in the desktop clie...
  • Exploring the infrastructure in Map, Floor and Rac...
  • Configuring the PUE DCiE
  • The look and feel of the ITA desktop client
  • Navigation
  • ITA toolbar
EcoStruxure IT Support
Request Support
Back to ITA desktop client
  • Mark as Read
ITA toolbar
Picard EcoStruxureIT
‎2019-11-06 07:13 AM
The ITA toolbar options depend on what part of the application is active and what add-on modules you have installed. When you are configuring the room layout in an editor, layout-specific icons are available such as move and add corners icons.
Saves changes made without exiting the display.
Undoes the last action that was performed, regardless of the active perspective. This function is identical to Edit> Undo.
Redoes the last action that was undone, regardless of the active perspective. This function is identical to > Edit> Redo.
Cuts the selected item or items. The selection is only marked for being cut and not actually cut away from its position until you paste it in another position. This function is identical to > Edit> Cut.
Pastes a selection of one or more items into this position. This function is identical to > Edit> Paste.
Opens the Configure Tags dialog box.
Opens the Genome Library from which to select products for the catalog.
Opens a new blank work order in the Work Order Editor in which to edit the work order.
Opens the list of discovered devices from external systems.
Opens the room layout for managing the floor and rack layouts (add, move, delete, or edit) for any room.
Opens the List View for managing any room (add, move, delete, or edit) in a table layout.
102237564_360037995614.png102237564_360037995614.png Opens the Power Path Layout for viewing a graphical overview of the power connections.
Opens the Map View for viewing a geographical representation of the data center infrastructure.
Opens the 3D View for viewing the data center temperature map in a 3D layout.
Toggles display of the control panel.
Opens a save dialog box to save a screenshot of the 3D layout.
