How to update the firmware on a Smart-UPS connected to EcoStruxure IT
IT Expert via ethernet port
Monitor your APC Smart-UPS in EcoStruxure IT Expert using its ethernet port or a Network Management Card (NMC)
  • EcoStruxure IT Help Center
  • IT Expert
  • IT Expert via ethernet port
  • How to update the firmware on a Smart-UPS connected to EcoStruxure IT
  • Mark as Read
  • Monitoring APC Smart-UPS in EcoStruxure IT
  • EcoStruxure IT features available for Smart-UPS
  • How to register a Smart-UPS using the EcoStruxure ...
  • Does a Smart-UPS with a SmartConnect ethernet port...
  • How to update the firmware on a Smart-UPS connecte...
  • Can I register my SmartConnect-compatible UPS with...
  • How to delete a Smart-UPS from the SmartConnect po...
  • How to remove a Smart-UPS from EcoStruxure IT
SmartConnect Support
Request Support
Back to IT Expert via ethernet port
  • Mark as Read
Picard EcoStruxureIT
‎2020-08-18 02:29 AM
Last Updated: Sisko JLehr Sisko ‎2025-08-20 10:41 AM
Smart-UPS connected to EcoStruxure IT using an NMC
If your Smart-UPS is connected to EcoStruxure IT using a Network Management Card and you subscribe to IT Expert, you can update the NMC firmware directly in IT Expert.
Log in to IT Expert and go to Management > Firmware Update. See Firmware update
To update the firmware on the Smart-UPS device, use a serial or USB connection and the Smart-UPS Firmware Upgrade Wizard.
Smart-UPS connected to EcoStruxure IT using the ethernet port
If you registered your Smart-UPS with EcoStruxure IT using its ethernet port, you update the firmware on the device using a serial or USB connection and the Smart-UPS Firmware Ugrade Wizard.
You'll find the latest firmware for your device in the wizard.
See APC FAQ FAQ 279197
Comments
A360
A360
Cadet
  • Mark as Read
‎2025-08-06 09:08 AM
So, you are saying a Smart Connected UPS using the ethernet cable CANNOT be updated through IT Expert, even though it CAN be updated through the Smart Connect portal?  If that is the case, it makes ZERO sense to move it off of the Smart Connect portal!!!!!!!!
dmarchewka
dmarchewka
Cadet
  • Mark as Read
‎2025-08-07 08:49 AM
UPS NMC firmware, just to clarify, not the UPS firmware.
