How to register a Smart-UPS using the EcoStruxure IT mobile app
IT Expert via ethernet port
Monitor your APC Smart-UPS in EcoStruxure IT Expert using its ethernet port or a Network Management Card (NMC)
Send InviteCancel
You can use the EcoStruxure IT mobile app to register your Smart-UPS in EcoStruxure IT when you connect it using the SmartConnect port.
Before you begin
Set up your Smart-UPS and connect it to your network using the SmartConnect port. See the instructions that came with your product.
After you power on the Smart-UPS and connect the ethernet cable to your network, wait a few minutes to allow the Smart-UPS to connect to the EcoStruxure IT cloud.
Enter your email address, password, and your mobile phone number including the country code.
Once you sign up, you'll see a confirmation message that your account was created.
Follow the on-screen instructions to download the EcoStruxure IT mobile app.
Select an authentication method and enter the code to proceed.
Create an organization to complete your registration. Note: Do not download the EcoStruxure IT Gateway.
Instructions
Log in to the EcoStruxure IT mobile app.
If you don’t have any devices connected to EcoStruxure IT, you'll see this screen.
Click Register.
OR
If you have already connected devices to EcoStruxure IT, tap Devices, and tap the three dots in the top right corner.
Click Register Smart-UPS.
Click Scan QR Code.
The QR code label may be on the front, side, or rear of your UPS.
If you haven’t accepted the Camera permission, you will be prompted for permission before you can use the QR Scanner.
Position the QR code on the Smart-UPS label inside the green indicator on the screen to scan it, or you can tap Enter manually to type the ID and Product Key if you prefer.
Once the Smart-UPS is registered in EcoStruxure IT, it can take up to 5 minutes for the first sensor values to be available. Click Show Device Details to view.
