ITA : Error - Perl execution failed
  • EcoStruxure IT forum
  • ITA : Error - Perl execution failed
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 07:57 PM . Last Modified: ‎2024-04-03 01:23 AM
1028
The Application is running but cannot log in.
What is the cause of this error and How to fix this?
(CID:144868826)
  • Data Center Operation
  • IT Advisor
  • bug
Replies 4
Hi Tanawat,
Can you please add more details about this installation/setup.
Is it a usual/normal installation or customized installation?
did it work before?
what changes have been done just before appearance of the issue?
Kind regards
(CID:144868949)
I have installed on VM last week and it works.
Only upload back up, restore and create a new floor plan.
Now root file system is used 99%.
(CID:144869203)
Hi Tanawat,
It seems the sever dose not have enough resources such as storage capacity.
System requirements/recommendations are described here:
https://sxwhelpcenter.ecostruxureit.com/display/UADCO8x/System+requirements
I would recommend a clean installation, the minimum recommendation is 4 CPU, 16 GB RAM and at least 100 GB storage, and then restoring the latest backup file.
Please let me know, if you have questions, thanks.
Kind regards
(CID:144869252)
Posted: ‎2020-07-05 07:57 PM . Last Modified: ‎2023-10-22 02:40 AM
