Exporting Cooling Data to 3rd Party Applications
Configuring cooling
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Configuring the ITA desktop client
  • Configuring cooling
  • Exporting Cooling Data to 3rd Party Applications
  • Mark as Read
  • Understanding Real-time Temperature Predictions
  • Tips and tricks for configuring cooling
  • Row-based or room-based cooling
  • Optimizing the Cooling Configuration Accuracy by A...
  • Designs with CRAC Units Placed Outside the Room
  • Cooling Redundancy
  • Cooling Configuration Accuracy and Design Guidelin...
EcoStruxure IT Support
Request Support
Back to Configuring cooling
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-06 07:13 AM
Exporting cooling data to 3rd party applications
If you want to export cooling data from IT Advisor and use it in other applications, you can use the export options.
In File>Export, select the type of data to export and export it to your local or network drive.
Export types and formats
  • Temperature map in Comma Separated Values file format
  • Plenum airflows in Comma Separated Values file format
  • Computational Fluid Dynamics model in (APC by Schneider Electric, open) xml file format
  • Computational Fluid Dynamics model in (FloVENT) PDML file format
