Cooling Redundancy
Configuring cooling
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • Configuring the ITA desktop client
  • Configuring cooling
  • Cooling Redundancy
  • Mark as Read
  • Understanding Real-time Temperature Predictions
  • Tips and tricks for configuring cooling
  • Row-based or room-based cooling
  • Optimizing the Cooling Configuration Accuracy by A...
  • Exporting Cooling Data to 3rd Party Applications
  • Designs with CRAC Units Placed Outside the Room
  • Cooling Configuration Accuracy and Design Guidelin...
EcoStruxure IT Support
Request Support
Back to Configuring cooling
  • Mark as Read
Cooling Redundancy
Picard EcoStruxureIT
‎2019-11-06 07:13 AM
Cooling redundancy
In IT Advisor, cooling redundancy refers to the amount of redundant cooling units in this way:
  • N: There are no redundant cooling units for the rack.
    There are one or more coolers in the data center. If ONE cooler fails anywhere in the data center, it would result in inadequate cooling (yellow or red CI).
  • N+1: There is one redundant cooling unit for the rack.
    ONE cooler (CRAC, row-based, or OA unit) can fail anywhere in the data center and cooling will still be adequate (green CI).
  • N+2: There are two redundant cooling units for the rack.
    TWO coolers (CRACs, row-based, or OA units) can fail anywhere in the data center and cooling will still be adequate (green CI).
  • N+x: There are x redundant cooling units for the rack.
    X coolers (CRACs, row-based, or OA units) can fail anywhere in the data center and cooling will still be adequate (green CI).
