Row-based or room-based cooling
Configuring cooling
Send InviteCancel
Cooling is distributed through InRow® cooling units placed in the rows close to the heat generating equipment.
Room-based cooling
Cooling airflow is distributed through perforated tiles in a raised floor environment. Cooling calculations include airflow distributed via perforated tiles for equipment spanning cold aisles with perforated tiles positioned in the cold aisle.
