Designs with CRAC Units Placed Outside the Room
Configuring cooling
Send InviteCancel
Starting from version 7.4 IT Advisor allows modeling of ceiling tiles, downflow CRAC units with air duct to ceiling plenum and cooling units placed outside a room.
Add CRAC units by dragging them from the Genomes pane into the layout. Place them outside the room, but touching room walls.
Enable Duct to ceiling by right-clicking the item, and selecting Properties, and using the settings in the Cooling page.
Configure room to use Drop ceiling.
Drag ceiling tiles from the Genomes pane into the layout. Add at least one ceiling tile for each CRAC unit. Place these tiles touching the same wall as CRAC unit.
