Using Telnet to test connectivity
  • Using Telnet to test connectivity
  • JohnBoehmer
    JohnBoehmer
  • LocNguyen
    LocNguyen
  • AdamSteele
    AdamSteele
  • GavinHe
    GavinHe
  • RandyDavis
    RandyDavis
  • Mahmoud_Sayed
    Mahmoud_Sayed
Lieutenant JG LocNguyen Lieutenant JG
‎2020-01-27 11:23 AM
Last Updated: Guinan AdamSteele Guinan ‎2023-08-16 11:11 PM
How to use the Telnet command to troubleshoot network connectivity and check for blocked network ports.
TAC INET, TAC Vista, Andover Continuum, Satchwell MicroNet, Satchwell Sigma, TAC IA Series, Field Devices, EcoStruxure Building Operation, Other, Pelco, EcoStruxure Building Expert, Access Expert, Security Expert
  • TCP/IP Communication
  • Command Prompt
  • Telnet Command
Suspect certain network ports are blocked and need to verify
Note:- Telnet operates using the TCP protocol. UDP connectivity cannot be tested using Telnet.
[video]
  1. Open Windows Command Prompt
  2. Enter :telnet <address_of_remote_server> <port_number>" - telnet 192.168.1.2 443
    1. Result if Port open: blank window with blinking cursor
    2. Result if Port closed: error message displayed similar to "Connecting To 192.168.1.2…Could not open connection to the host, on port xx: Connect failed"
  3. The example above test for connectivity against the remote server that has the IP address of 192.168.1.2 over port 443
Labels (7)
  • EcoStruxure Security Expert
  • EcoStruxure Workplace Advisor
  • TAC IA Series
  • TAC INET
Tags (5)
  • AdamSteele23
  • GavinHeward23
  • locnguyen20
  • MahmoudSayed22
  • telnet
80% helpful (4/5)
