Controllers used to get values from a Modbus device into TAC Vista
  • Controllers used to get values from a Modbus device into TAC Vista
‎2018-09-07 04:05 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:37 AM
What kind of controller can be used to get values from a Modbus device into TAC Vista? For example, getting data from a Modbus meter into a BMS system running Vista.
TAC Vista
  • TAC Xbuilder
  • TAC Xenta server 731/913
TAC Vista can not talk Modbus directly so you need to use a gateway controller.
Xenta firmware version 5.1.4 and earlier only two controllers had Modbus communication capabilities:
  1. Xenta Server 731  For details see
    TAC Xenta 711/731 Web Server and Controller
  2. Xenta Server 913 For details see
    TAC Xenta 913 LonWorks Gateway
Starting with Xenta firmware version 5.1.5, all Xenta Servers are now capable of communicating on a Modbus network both via TCP/IP and RS-485.  This includes Xenta 511, 527, 701, 711, 721, 731, 913.
Note: Older Xenta Server devices built before firmware 5.1.5 have the capability of using Modbus over RS-485 once they have been upgraded even though the terminals are not labeled on the device. For information on how to wire these devices to reference a newer Xenta Server that does have the RS-485 A terminals labeled or see Xenta Server wiring and pinouts.
Tags (7)
  • 4270
  • 711
  • 731
  • 913
  • PeterLarsen20
  • xbuilder
  • xenta
