Access Expert V2 Report Viewer error loading ReportViewer.WebForms version 11 Generating a report
  • Access Expert V2 Report Viewer error loading ReportViewer.WebForms version 11 Generating a report
  • CraigEl
    CraigEl
  • Cody_Failinger
    Cody_Failinger
  • Alan_Wood
    Alan_Wood
  • David_Kendrick
    David_Kendrick
‎2018-09-10 09:03 AM
Last Updated: Administrator CraigEl Administrator ‎2021-12-21 03:31 PM
Cannot generate a report from Access Expert V2. Getting an error when attempting to generate the report
"Could not load file or assembly Microsoft.ReportViewer.WebForms, Version=11.0.0.0"
EcoStrucure Access Expert
  • Version 2
  • Report Viewer
  • Windows
The ReportViewer files that are from Feenics's website contain version 11. Microsoft does have older and newer versions of the file (i,e 10 and 12) so there is a potential that these files will not work.
To resolve this issue
1. Download the Microsoft Report Viewer (Feenics Training> Web App V2> Miscellaneous Downloads) http://www.feenics.com/Downloads/ReportViewer.zip
2. On the Access Expert application PC (Not the SQL Server PC in a 2 PC system)
    Uninstall all versions of Report Viewer and SQLClrTypes from Windows> Control Panel> Programs and Features
3. Stop the Feenics Keep Render Service
4. Unzip the Download files (Report Viewer.msi  and SQLClrTypes.msi) and install both of them
5. Restart the Feenics Keep Render Service
Test Reports
6. If they are still not working, reboot the Access Expert PC and test again. If this is still not working, contact your local country support.
  • EcoStruxure Access Expert
Tags (3)
  • 19982
  • ax
  • DavidKendrick21
