Access Expert Premise Install Documentation
Select a Country
  • Access Expert Premise Install Documentation
  • Alan_Wood
    Alan_Wood
  • Cody_Failinger
    Cody_Failinger
  • Taylor_Leach
    Taylor_Leach
  • CraigEl
    CraigEl
  • Roger_Bently
    Roger_Bently
  • Robert_Davis
    Robert_Davis
‎2018-09-11 11:50 AM
Last Updated: Alan_Wood Leader ‎2023-06-28 05:45 AM
How to Prepare a Server for Access Expert Premise Software
Access Expert V2 On-Premise ONLY
Windows Server 2012 and above
There is no documentation on how to prepare a server for a Premise Install.
In order to do this there are several pieces that needs to be followed on how to configure it correctly. First step is to install the server software, in this case Windows Server 2012:
  3. Server Selection, select a server (should be the local machine)Server Selection.jpg
  4. Click Next a few times, to complete this part
  5. Scroll down to the bottom and select WebServer IIS and add all features
  6. Click Next to complete this part
  9. Expand WCF Services
  12. Expand and scroll down to SMTP Server - Add Feature, Click next a couple of times to installMessage Queing.jpg
Installing SQL Server
  1. Open media where software is located and launch the installer
  2. Select the option to Install a new instance and click Next
  3. Select Install DB Engine and Mgmt Tools, click NextDB Engine and MGMT Tools.jpg
  5. Use same service accounts, click on Server Configuration TabAccount Setup.jpg
  7. Select the Data Directories Tab, change where the data files are stored by defaultChange Directories Path.jpg
  11. Click on next and Install
  12. Once finished, close out to complete the install.
Installing Keep
Here is a link of a video that goes through this process as well.
Premise Installation of Keep for Access Expert
  1. Download Keep By Feenics software from the Software Downloads Tab on the Feenics training site http://www.feenics.com/training/courses/technical-certification/
  2. Browse to the location and launch Keep Installer, click on NextKeep Installer.jpg
  3. When complete, Test Db Connection, once it passes, click on NextDB Connection.jpg
  4. Make sure all elements are selected, click on Next to installAll elements.jpg
  5. Launch the Keep Instance Management, click on Connect
  7. Give the site a name that will used for the instance (if this name is changed, it would require a new instance license key to be generated)Instance Configuration.jpg
  8. Give a url to the name
  9. db name with username and password (admin/admin)
  10. Change the path for file location and DB Log location from earlier steps
  13. Add a new Binding, check the Box for "Do not show messages"Bindings1.jpg
  14. Delete the default website
  15. Click on created website and select Bindings
  17. Start IE Browser (url) created earlier
  19. Log in to the system.
Host File
If the browser does not start and fails to open the page, then modify the Host File to contain the IP address of the server as well as the URL of the instance
  1. Go to C:\Windows\System32\drivers\etc hosts
  2. Modify the file by entering the IP address of the server as well as the URL
  3. Save and close.
  4. Open up the page again and it should allow the application to be started.
For V3 On-Premise Installation Instructions, see the following link:
https://ecoxpert.se.com/search?documentUUID=846b8347-4412-42ad-a983-53ef97bb5cc4&title=AccessXpert%2...
  • EcoStruxure Access Expert
Tags (5)
  • 19196
  • Access Expert
  • AlanWood23
  • on-prem
  • onpremise
