Serial Connection Trouble
  • Serial Connection Trouble
Posted: ‎2021-06-30 08:15 PM . Last Modified: ‎2024-03-07 12:30 AM
969
I am using Tera Term terminal emulation software and cannot get the serial connection to work on a SURT8000 unit.
I carefully set the connection with the settings from the manual like 2400 baud...
I am using the serial cable that was provided with the unit.
What terminal software do you  recommend?
Will any serial cable work or does APC have unique cable?
MarkC_apc
Commander MarkC_apc
Commander
Hyperterminal has worked for me.  You must use an "approved" cable that has some pins switched!  You might try 9600 baud - or others if it's possible someone has set it at a "custom" rate.
MarkC_apc
Commander MarkC_apc
Commander
