SMX3000RMLV2UNC Failure bypass
  • SMX3000RMLV2UNC Failure bypass
Posted: ‎2021-06-30 08:15 PM . Last Modified: ‎2024-03-07 12:30 AM
2519
Hi, Have an SMX3000RML with an extended battery pack that is in bypass mode error on the unit LCD showed "misc. fault" and "failure bypass". From what i can see in the logs it showed that it was in bypass mode because one of the batteries temp was too high putting it in bypass mode. The temp went back down to normal but it is still in bypass mode. Batteries are probably getting close to 5 years old since the unit showed battery was installed in 2012.
will rebooting the unit clear the fault?
Hi Long,
Good day to you. That would be one troubleshooting step to try fixing the problem. You may also want to do the steps on this article:
http://www.schneider-electric.com.ph/sites/philippines/en/support/faq/faq_main.page?page=content&cou...
This is going to clear out static energy on the unit that could cause some of the components to misbehave.
Hi Long,
