Low runtime remaining on SMART-UPS RT 3000 XL
  • Low runtime remaining on SMART-UPS RT 3000 XL
Posted: ‎2021-06-30 10:37 PM . Last Modified: ‎2024-03-06 10:49 PM
2995
we had a power failure last week on our Smart UPS RT 3000 XL.
We bought it on March 14 2013 (with network card AP9630).
We have a low runtime remaining of 28min 17sec.
Here are the other value given :
UPS Input
Input Voltage: 219.5 VAC @ 50.0 Hz
UPS Output
Output Voltage: 230.0 VAC @ 50.0 Hz
Load Current: 4.4 Amps
Output VA: 33.8 %
Output Watts: 44.6 %
Battery Status
State of Charge: 100.0 %
Battery Voltage: 218.3 VDC
Num of External Batteries: 0
I am not sure to change the battery or not ?
Is there an other problem ?
Could someone help me ?
Laurent.
michael,
Here is the screen shot of the APC :
APC screenshot
Can you see runtime remaining and the "Last Battery Transfer" status ?
Do you think it's normal ?
Thanks.
Laurent.
Replies 7
Where are you seeing the error? On the NMC or in PowerChute and if PoewrChute what version? Can you provide the event log/s for each if using PowerChute and what is low battery threshold set for on the NMC?
I am seeing the error on the nmc web page.
NMC version : hw05_aos640_sumx640_bootmon108
I think (but i am not sure) that low battery duration is 5 minutes.
Please find attached the event log.
Thanks.
Laurent.
mitsmith_apc
Lt. Commander mitsmith_apc
Lt. Commander
Laurent,
After looking over your event log, I do not see any low runtime warnings. I see a couple instances where the unit went on battery due to distorted input but that is normal and the unit transferred back off of battery once the input power returned to normal. Overall the unit seems to be in good health. Is there a particular date and time when you saw this?
michael,
APC screenshot
Thanks.
Laurent.
Hi Laurent,
Regarding the "Last Battery Transfer" status, I get the identical message when I pull the plug on the UPS to simulate a real power outtage.
To me, with your UPS loaded to about 40% or so, I think your "run time remaining" indication is reasonable.
Joe
mitsmith_apc
Lt. Commander
I Agree With Joe. The runtime is right in the expected range for the amount of load you have attached to the unit. If you would like more runtime you can added additional battery packs.
-Mike
You can buy external batteries to increase the runtime.
