Deleting old work orders
Work orders
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA Change
  • Work orders
  • Deleting old work orders
  • Mark as Read
  • Working with work orders
  • Work order reports
  • User roles when working with work orders
  • Executing work orders using the web client on mobi...
  • Creating and applying work order processes
  • Creating a custom work order without recorded task...
  • Creating a controlled automated work order
EcoStruxure IT Support
Request Support
Back to Work orders
  • Mark as Read
Picard EcoStruxureIT
‎2020-04-23 07:39 AM
Over time, the amount of old work orders in the system will grow. You can perform a cleanup and delete work orders older than 400 days, that is work orders with a Needed by date of minimum 400 days prior to today's date.
Note: Use this operation with caution. Once performed, there is no way of retrieving deleted work orders.
  1. Select System Setup>Work Order Cleanup.
  2. Type the minimum age of the old work orders to be deleted.
  3. Type the confirmation text CONFIRM. Type exactly what it says and be sure to enforce case sensitivity.
    This step has been added to prevent you from unintentionally deleting work orders by accident.
Work order related data in the audit trail log will not be deleted.
