Creating a custom work order without recorded tasks
Work orders
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA Change
  • Work orders
  • Creating a custom work order without recorded tasks
  • Mark as Read
  • Working with work orders
  • Work order reports
  • User roles when working with work orders
  • Executing work orders using the web client on mobi...
  • Deleting old work orders
  • Creating and applying work order processes
  • Creating a custom work order without recorded task...
  • Creating a controlled automated work order
EcoStruxure IT Support
Request Support
Back to Work orders
  • Mark as Read
Picard EcoStruxureIT
‎2020-05-07 04:25 AM
You can create, review, and edit custom work orders without recorded tasks.
  1. In Planning > Data Center, click the create new work order icon to open the Work Order.
  2. Select No process to add tasks to the work order. Selecting a process may restrict whether you can add tasks to the work order.
  3. Edit the work order details, such as summary, assignee, needed by date, and priority.
  4. Select a project code (not required).
    The project code can be used to identify the work order type and you can filter the work order list using this code. To add a new code, type the code directly in the field or select Tools > Create Work Order Project Codes and add the new code.
  5. Type a comment (not required).
  6. Click Create new task if you want to add one or more tasks.
  7. Edit the task details.
  8. Add more tasks if needed.
  9. Save and close the Work Order.
