Working with work orders
Work orders
Send InviteCancel
You can enable the controlled automated work order process in the Planning > Data Center perspective by opening the Work Order Editor and making changes to the layout. Any changes done to add, move, or delete IT equipment are recorded, and work order tasks for implementing these changes in the data center are automatically generated.
Each work order has its own unique workflow. To create or modify a workflow,click the Workflow icon on the work order header --> ITA_Workflow_Icon_360007722958.jpg to open the Work flow Editor.
You can view work orders in a list without opening theWork Order EditorinPlanning > Data Center(and read-only inOperations > Data Center) in theWork Orderspane if you haveIT Advisor: Changeinstalled.
In theWork Orderspane, double-click a listed work order.
Edit or view the selected work order in theWork Order Editor.
Edit the work order summary and details.
Add, edit, or delete task details.
Filter work orders
To limit the amount of work orders in the list to only include those you want to edit:
Use the search filters below the column headers in the pane.
Use the link icon to only see work orders related to the selected equipment.
View, print or export work orders
To access print and export options for the work order list, multi-select work orders (Ctrl+click or Shift+click) and selectPrint Work Order List. The report view opens and you can click thePrinticon and thenExporticon to export it as a PDF, HTML, or XLS document.
To view or print an audit report, listing the tasks in a selected work order, right-click a work order and selectAudit Work Order. The report view opens and you can click thePrinticon and thenExporticon to export it as a PDF, HTML, or XLS document.
Set up strict work orders
You can set up strict work orders that require work orders to follow a selected process. The option to select 'No process' when a work order is created is not available when this setting is applied in theTools>Preferences>Generaloption.
