Creating and applying work order processes
Work orders
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA Change
  • Work orders
  • Creating and applying work order processes
  • Mark as Read
  • Working with work orders
  • Work order reports
  • User roles when working with work orders
  • Executing work orders using the web client on mobi...
  • Deleting old work orders
  • Creating a custom work order without recorded task...
  • Creating a controlled automated work order
EcoStruxure IT Support
Request Support
Back to Work orders
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-02 07:05 AM
Working with change management in a data center often requires certain tasks to be repeated regularly. In ITA, work order processes and the option to schedule recurring work orders help you manage repetitive tasks.
A work order process is a list of tasks in a defined flow that you can save and reuse for other similar work orders. As you add to it, your processes library will grow into a valuable collection of best practices.
Creating a work order process is very similar to creating a work order. The only difference is the list of tasks and the flow you create in a process can be saved and used again and again.
  1. Click the Create new Work Order Process icon 114820815_360036208334.jpg114820815_360036208334.jpg in the menu bar.
  2. Fill in the work order process properties, such as name, priority, project code, etc.
  3. Add one or more tasks to the work order process.
  4. Open the Work Flow Editor.
  5. Define the workflow.
  6. Click the Create work order recording task icon 126177527_360036208334.png126177527_360036208334.pngto insert tasks that are work order specific, if needed.
    For example, the process to install a server is always the same, but the rack, u-position, etc. is different every time.
    Note: You can only add one work order recording to a process, however, you can add many tasks within that recording.
Work Order Process View
The saved work order process appears in the list of available processes when you create a new work order. and in the Work Order Processes view.
Note: The Work Order Processes view is not displayed by default. Go to Window > Show View > Work Order Processes to open it.
Applying a work order process
  1. Right-click one or more pieces of equipment or a room layout, and select Apply Work Order Process.
  2. In the Work Order Editor, adjust the text for the work order if needed.
    Tip
    Ctrl-click or Shift-click to select multiple items at the same time.
    See also
    Scheduling Work Order Recurrence
    Locking a work order
