Scheduling work order recurrence
Configuring work order administrative settings
Send InviteCancel
Often, working with change management in a data center requires certain tasks to be repeated.
In IT Advisor, work order processes and the option to schedule recurring work orders assist you in managing repetitive tasks.
A recurring work order will recur in theWork Orderspane with a given interval.
Configuring a work order recurrence schedule
Open the work order for which you want to schedule recurrence.
Click theAdministrative Settingsicon and selectSchedule recurrence.
In theSchedule Work Order Recurrencedialog box, selectRecur everyand set the interval for the work order to recur.
After this configuration, when you complete a work order for which you have configured recurrence, it will show up again as a copy with a new scheduled needed by date and a status of not started.
