  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      • Protection & Control
      APC UPS, Critical Power, Cooling and Racks
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • Alliance System Integrators Forum
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • EcoStruxure Automation Expert / IEC 61499 Forum
      • Fabrika ve Makina Otomasyonu Çözümleri
      • Harmony Control Customization Forum
      • Industrial Edge Computing Forum
      • Korea Industrial Automation Forum
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Eldistribution & Fastighetsautomation
      • Elektrik Tasarım Dağıtım ve Uygulama Çözümleri
      • Paneelbouw & Energie Distributie
      • Power Distribution and Digital
      • Solutions for Motor Management
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      • Power Monitoring and Energy Automation NAM
      Power Distribution Software
      • EcoStruxure Power Design Forum
      • LayoutFAST User Group Forum
      Energy & Sustainability Services
      • Green Building Scoring and Certification Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      • Solutions for your Business Forum
      Support
    • Remote Operations Devices Knowledge Base
    • Geo SCADA Knowledge Base
    • Industrial Automation How-to videos
    • Digital E-books
    • Success Stories Corner
    • EcoStruxure IT Help Center
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      • EcoStruxure Building Advisor Ideas
      Remote Operations
      • EcoStruxure Geo SCADA Expert Ideas
      • Remote Operations Devices Ideas
      • Modicon Ideas & new features
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • Active Energy Management Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
Important Announcement: Community Back to Full Functionality
Dear Members, we are thrilled to announce that our Community is back to full functionality and that posts publication is now enabled again! We appreciate your patience during the last weeks. Learn more about our Community Guidelines. Thank you, Schneider Electric Community Team.
iTRV Not Closing
  • Communities
  • iTRV Not Closing
  • Subscribe to RSS Feed
Alfred_SE
Lt. Commander Alfred_SE Lt. Commander
23
nischaypond
Ensign nischaypond Ensign
4
sesa96364
Lieutenant sesa96364
2
MikeP007
Crewman MikeP007
1
Fozzie1960
Crewman Fozzie1960
Crewman
Posted: ‎2023-01-24 12:54 AM
842
iTRV Not Closing
Ever since I installed Wiser I’ve had an issue with iTRVs not closing after the set point has been reached. Drayton diagnosed the issue has incompatible valve heads, i.e non Drayton. They came to this conclusion from photos I sent to them. So I changed two valves, one upstairs and one downstairs. The problem didn’t go  away. Drayton then put the blame on my Wifi connection. I borrowed a wifi tester from work and checked the signal in every room. The worst signal was -60dBm. The signal at the hub was -52dBm. Even with this evidence Drayton still put the blame on my network, which is fully meshed by the way.
I’ve reached the point where I’m fed up with resetting valves to make them close and rooms overheating.
I would like to know if anyone else has experience this issue and have they managed to fix it.
  • Temperature Control
Replies 7
PhilHornby
Lieutenant PhilHornby
Lieutenant
Posted: ‎2023-01-24 06:56 PM . Last Modified: ‎2023-01-24 07:00 PM
If the iTRV closes when you twist the cap (blue light) and opens when you twist it the other way (red light), then I think you can say it functioning correctly mechanically.
Assuming that is the case, then you probably have Zigbee comms. issues. Zigbee operates on 2.4GHz and so can suffer interference from Wi-Fi (Wi-Fi always seems to win!). There is no (official) way of displaying which Zigbee channel is in use - and in any case, you can't change it. You could try arbitrarily changing the 2.4GHz channel of your Wi-Fi to see if it improves matters.
Otherwise, you will need to purchase a 'Smartplug', which acts as a Zigbee Repeater. (Zigbee Repeaters have to be mains-powered). Again, there is no (official) way of displaying the Zigbee signal levels (which would aid your purchasing decision...)
3 Channel Hubᴿ, 13xiTRVs, 8xRoomstats and 2xSmartplug/Repeaters. (UK)
turnah
turnah
Cadet
Posted: ‎2023-01-27 12:51 AM
762
I have the same issue and have had a call open with Drayton for weeks, not getting far with it.
My bedroom is currently set at 17 degrees yet is 21 degrees with the radiator hot. So frustrating - there is an issue as it only started happening in the last month or so. It is also happening in other rooms. I have a home assistant setup and can see strong connections on the zigbee mesh.
When i reset the TRV it closes completely, then within 30 seconds opens itself again.
You're not alone and i'm pretty angry after the amount of money i've spent on this system, it's actually costing me more than my Hive. Support is weak at best.
Fozzie1960
Crewman Fozzie1960
Crewman
Posted: ‎2023-01-27 01:19 AM . Last Modified: ‎2023-01-27 01:20 AM
In response to turnah
Interesting you say that because our kitchen is the room that suffers the most with this phenomenon. Interesting because the iTRV has direct line of sight to the Hub and there’s also a smart plug in the room.
david101
Ensign david101
Ensign
Posted: ‎2023-01-27 07:34 AM
What SW version are you guys running?  I am on ea64 and I don't have this issue.  I have other issues though like the inaccurate temperature calculations.
Fozzie1960
Crewman Fozzie1960
Crewman
Posted: ‎2023-01-27 09:09 AM
ea64
turnah
turnah
Cadet
Posted: ‎2023-01-27 09:29 AM
Ea64 here too
PhilHornby
Lieutenant
Posted: ‎2023-01-27 04:02 PM . Last Modified: ‎2023-01-27 04:03 PM
@turnah wrote:
When I reset the TRV it closes completely, then within 30 seconds opens itself again.
By 'reset', do you mean re-calibrate?
If this phenomenon is repeatable, you could try temporarily shutting down Home Assistant and see if it still does it. You could also try with the Hubᴿ temporarily powered-off.
(I'm wondering if it's the valve itself that's gone bonkers, or HA telling the Hubᴿ to take some particular action - or possibly even the Hubᴿ itself.  Trying fresh batteries would do no harm either.)
I don't know if the iTRVs act autonomously, or if they only follow commands from the Hubᴿ.
Additional options
You do not have permission to remove this product association.
You can subscribe to this forum after you log in or create your free account.
Terms & Conditions Privacy Notice Change your Cookie Settings © 2023 Schneider Electric, Inc
