User | Count |
25 | |
12 | |
10 | |
5 |
Posted: 2023-01-15 04:20 AM
Noticed if i get up for a wee in the middle of the night the heating is on/has been on (warm radiators)
Heating and water heater are scheduled off all during the night
I did notice this before we had the system installed so its not a Wiser issue
Just wanted to know if there was some way to track when it comes on in the night?
Cheers
Posted: 2023-01-15 06:31 AM . Last Modified: 2023-01-15 06:33 AM
Normally, the Hubᴿ activates a zone valve which, in turn, activates the boiler and pump when it opens. The state of the boiler itself isn't known (Opentherm could muddy the waters?) - but the RelayState is accessible via the API. However, you say it happened before Wiser was installed, so it sounds like something external anyway.
Is the boiler in a 'cold' location, protected by a Frost-stat? The weather's just turned cold again, so maybe that is triggering it? (Frost-stats are adjustable, but you may have to remove a cover first).
@jjscruff wrote:Just wanted to know if there was some way to track when it comes on in the night?
An IR-sensitive wildlife camera? 😊
Posted: 2023-02-15 07:08 AM
On the Insights tab, the bottom section is "Heat Report". Perhaps if you select a specific room, you can tell from the graph at what time the temp started to rise.
