How to establish communication between 3 devices
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • How to establish communication between 3 devices
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
SCADAPack 300E
Modicon M580
Posted: ‎2022-04-19 06:24 AM
5259
Can someone help me understand how to establish communication between these three devices.
PLC - Modicon M580 BME P58 2040
Workbench - SCADAPack 300E TCP/IP
Vijeo Designer - HMI STU 855 touch panel
Much appreciated,
Thanks in advance
  • DNP3
  • Mimics
  • RTU
  • SCADA
  • Telemetry
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
Replies 6
Mnabil
Lieutenant JG Mnabil Lieutenant JG
Lieutenant JG
Posted: ‎2022-04-19 08:13 AM
5
5221
Hi St123,
for HMI Communication it is very simple, please follow the attached print-screen setting after connecting the HMI to the service port of CRA
Also for communication between M580 HSBY and SCADAPack also you can use DTM request or ReadVar and WriteVar.
I attached print screens for the DTM approach
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Posted: ‎2022-04-19 09:33 AM
In response to Mnabil
5198
@Mnabil Thank you for your reply, much appreciated for getting back to me as soon as possible. Just a question, I'm guessing on the address settings, the IP address will be the address of the RTU?
Thanks in advance.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Mnabil
Lieutenant JG
Posted: ‎2022-04-19 01:37 PM
In response to Anonymous user
5185
Yes the equipment address window, is the IP address of M580 or SCADAPACK ; you will need to add two Modbus equipment (one for M580 and One for SCADAPACK)
For the M580 Connection, Please make sure you marked the M580 Redundant CPU in the bottom part of the window.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Posted: ‎2022-04-19 04:11 PM
5180
Thank you. I'm assuming both modus equipment will have the same request settings as DTM 4.png?
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Posted: ‎2022-04-19 07:42 PM
5171
Sorry for this mix up, could you please tell me how to connect the PLC M580 to the RTU via geoSCADA?
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2022-04-20 08:53 PM
You would generally not do this.
You might have:
PLC <-> RTU <-> GeoSCADA Expert
If you are in a low data bandwidth network (standard distributed telemetry network).
My preferred way to do this is to use the Modbus Scanner functionality of the SCADAPack (E series / x70 series) to do the ModbusTCP <-> DNP3 mapping.
Then you have DNP3 points for your GeoSCADA Expert.
You can configure both of these using the inbuilt GeoSCADA Expert configuration 'stuff' for the E series / x70 SCADAPacks also, so that the GeoSCADA Expert holds your entire RTU configuration.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
