RTU Modbus difference between PM5110 and PM5350
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • RTU Modbus difference between PM5110 and PM5350
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
Navarajan10
Navarajan10
Cadet
Posted: ‎2022-04-12 06:30 AM
Good Day Everyone!
I have some problem to read Modbus registers over RTU mode. I believe there are a lot of expert in this community. I will be grateful if you help me how to sort out this problem.
My objective is to read the current and voltage data using raspberry pi 4. I develop one code which make the raspberry pi4 to communicate with power meter using Modbus over RTU. I successfully manage to read the data using Schneider power meter (PM5350) but when I use Schneider power meter (PM5110) it fail. I saw the registers for both of power meter is same but still I cannot get the data from PM5110. I already check the wiring connection, baud rate and address. Everything is good but still I cannot get the data from the power meter.
Another curiosity is that every model have different offset of registers? If do so how to know about the offset?
Thank You.
Replies 0
