Continue
  • My Subscriptions
  • Events
PowerTag A9MEM1570
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PowerTag A9MEM1570
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Patrick_Grehan
Patrick_Grehan
Explorer
Posted: ‎2024-10-18 04:22 AM
1798
PowerTag A9MEM1570
Hi all,
Is it possible to use A9MEM1570 (3P + N) as a substitute for A9MEM15703 (3P) with neutral not connected? - Any feedback is appreciated.
Thanks.
  • PowerTag Energy
Jesus_Diaz
Jesus_Diaz Leader
Leader
Posted: ‎2024-10-22 12:36 PM
Hi @Patrick_Grehan,
Yes, this will fall under the first case: when the neutral is not connected (on load and PowerTag), the data by phase will be incorrect if the phases are not well balanced, but the total power/energies will be accurate.
JD
Replies 5
Jesus_Diaz
Jesus_Diaz Leader
Leader
Posted: ‎2024-10-21 11:55 AM
1
1785
Hi @Patrick_Grehan ,
Without information about the location and installation of the PowerTag (PTag) and assuming it is a 3P +N system, we can make the following observations:
  • When the neutral is not connected (on load and PowerTag), the data by phase will be incorrect if the phases are not well balanced, but the total power/energies will be accurate.
  • When the neutral is connected on loads but PowerTag is not connected to neutral, then if the phases are not well balanced, the total power/energies will be incorrect (because even though we are monitoring the current, the voltage vector sum cannot be accurate as the neutral voltage is missing).
Best Regards,
JD
Patrick_Grehan
Patrick_Grehan
Explorer
Posted: ‎2024-10-22 01:18 AM
Hi @Jesus_Diaz
Thanks for your response - to clarify, my question was around using the PTag on a 3P load (no neutral). Installing the 3P+N PowerTag (A9MEM1570) without the neutral connected, as per your comment above, may see some inaccuracy in phase data (if unbalanced) but overall power / energy data will be accurate. Have I summarised your response accurately?
PG
Jesus_Diaz
Jesus_Diaz Leader
Leader
Hi @Patrick_Grehan,
JD
Romain_Polette
Romain_Polette Champion
Champion
Posted: ‎2024-10-22 11:11 PM
1718
Hello @Patrick_Grehan ,
What are you going to do with the Neutral connector of your PowerTag F63 ?
Romain POLETTE
Solution Architect - France Operations
Patrick_Grehan
Patrick_Grehan
Explorer
Posted: ‎2024-10-23 02:45 AM
Hi Romain,
The neutral would not be connected and insulated. My question is basically if it's appropriate to do this.
PG
