Possible to stream waveform via Modbus TCP with PM8000?
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Possible to stream waveform via Modbus TCP with PM8000?
Charles_Murison
Picard Charles_Murison Picard
529
Mehran_Mehrnia
Admiral Mehran_Mehrnia Admiral
139
Ramasamy_N
Captain Ramasamy_N Captain
115
Posted: ‎2022-10-05 04:32 PM
4
1836
We would like to know if we could stream waveform data via Modbus TCP.  Need to send the waveform data (voltage and current) to an external application for further real-time analysis.
Or if there is any other method can be implemented to fulfill the some task will also do.
Your input is much appreciated.
  • PM8000
Posted: ‎2022-10-11 04:43 PM
Thanks a lot for the information. That helps a lot. @Charles_Murison
Replies 4
Charles_Murison
Posted: ‎2022-10-07 09:36 AM
1810
Hello @Anonymous user ,
Waveform data is not accessible via modbus. You can use COMTRADE and meter's sFTP to store and collect waveform data. Note that waveform data is logged and not real time.
Charles
Hanif777
Crewman Hanif777
Crewman
Posted: ‎2024-11-08 10:08 PM
917
Excuse me, but im trying to get the COMTRADE data from a PM5650, it says here that it's accessible via FTP or Modbus TCP
How to do it with modbus tcp?
Charles_Murison
Posted: ‎2024-11-11 10:26 PM
Hello @Hanif777 ,
I suggest you start a new topic and the original question is for a PM8000 meter. PM8000 and PM5560 meters are very different meters with different protocols and architecture.
Charles
