Hello @andrewback ,
When you say split-phase supply, are you referring to single phase? If so have you looked at install guide, search for "1PH Voltage/Current" to see how to wire depending on number of wires needed to connect to meter.
Charles
Hello @andrewback ,
Charles
Hi @Charles_Murison ,
Many thanks. I was looking in the User Guide and the Instruction Sheet / Installation document has details for "1PH3W LL with N" connection, which seems to be what I want and notes that with this volts mode should be set to single.
Andrew
