PM710 Power Analyzer LCD Display Failures and Replacement Options
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM710 Power Analyzer LCD Display Failures and Replacement Options
Charles_Murison
Charles_Murison Champion
571
Mehran_Mehrnia
Mehran_Mehrnia Champion
203
Ramasamy_N
Ramasamy_N Champion
115
Majid-Ikram
Majid-Ikram
Explorer
Posted: ‎2024-11-20 03:02 AM
1275
Spare Parts Availability
“Is the LCD display module of the PM710 still available in stock for purchase to repair the faulty meters?”
Expected Lifespan
4.1 What is the designed operational lifespan of the PM710 under standard conditions?
4.2 Specifically, what is the typical lifespan of the LCD display component in the PM710?
4.3 From when does the lifespan of the PM710 meter start (e.g., manufacturing date, installation date, or first use)?
  • PM Guidebooks
Charles_Murison
Champion
Posted: ‎2024-11-22 08:26 AM
Hello @Majid-Ikram ,
PM710 meters are obsolete 9 years ago. There is no replacement stock, there is no repair option. The display on the PM700 could not be replaced when parts were available. Meter will need to be replaced.
4.1) 15 Years under normal operating conditions. Each region will have different warranties, will need to contact your local sales channel to see what options could be available.
4.2) I do not have that information
4.3) Manufacture date
Replacement options will likely be PM5000 series or PM8000 series depending on the customer's needs.
Charles
Reply 1
Charles_Murison
Champion
Charles
