Continue
  • My Subscriptions
  • Events
PM5500 Calibration Failure HEX error
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM5500 Calibration Failure HEX error
Charles_Murison
Charles_Murison Champion
581
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
ClaytonGW
ClaytonGW
Explorer
Posted: ‎2025-09-10 01:30 AM
705
Good day,
I have a power meter installed at a client with very low values which dont look correct.
After verifying that all CT's and voltage references are correct, I noticed the "Wrench" icon showing that an error was present. the HEX code 0011 HEX which shows "Calibration failure" is present.
Can this issue be fixed or does the meter need to be replaced?
  • PM5000
Tags (2)
  • Calibration Failure
Romain_Polette
Romain_Polette Champion
Champion
Posted: ‎2025-09-10 05:20 AM
1
700
Hello @ClaytonGW ,
Please have a glance on this FAQ:
https://www.se.com/be/fr/faqs/FA324761/
At the end you can read: "an error code of 0011 denotes a calibration failure. In this scenario, the meter should be returned as part of the RMA process."
Try to upgrade or reflash the FW. If your issue is not solved, you need to return the product if under warranty.
Romain POLETTE
Solution Architect - France Operations
Romain_Polette
Champion
1
700
Hello @ClaytonGW ,
Romain POLETTE
ClaytonGW
ClaytonGW
Explorer
Posted: ‎2025-09-10 05:32 AM
Perfect, Thank you very much.
