EM3570
Metering & Power Quality
Send InviteCancel
2025-09-1008:03 AM
EM3570
Good day Team
Could you please provide clarification regarding the EM3570 meter:
Tariff switching is triggered by a change in the input status ofS-In. Will this input change cause the meter to switch registers for kWh readings, or will it continue recording on the same register?
In the EM3570 meter, when the S-In input triggers a tariff change, the meter switches to a different kWh register corresponding to the active tariff, allowing energy to be recorded separately for each tariff.
