Continue
  • My Subscriptions
  • Events
PM5340 Modbus TCP/IP device address
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM5340 Modbus TCP/IP device address
Charles_Murison
Charles_Murison Champion
581
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
PowerLogic ION9000
PowerLogic PM5000 series
sesa427078_brid
sesa427078_brid Explorer
Explorer
Posted: ‎2023-01-05 08:13 PM . Last Modified: ‎2023-03-16 01:21 AM
5234
HI Team,
Can i change the Modbus TCP/IP device address for PM5340? is the BACNET device address can be use for modbus device addreess if BACNET is disabled?
BR,
SESA427078
  • Thumbnail of PowerLogic ION9000
    PowerLogic ION9000
  • Thumbnail of PowerLogic PM5000 series
View products (2)
  • PM5000
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2023-01-09 10:02 PM . Last Modified: ‎2024-09-24 08:36 AM
5202
Hello @sesa427078_brid
The Modbus unit ID is fixed as 255 and it cannot be changed since the PM5340 is standalone Modbus TCP device. The default BACnet device ID will be the last 3 digit of PM5340 meter serial number and it cab be changed by the user if required.
Ramasamy N
Replies 5
Charles_Murison
Champion
Posted: ‎2023-01-09 09:27 AM
Hello @Ramasamy_N ,
Do you know if possible to change the modbus device address for modbus TCP on PM5340 meters?
@sesa427078_brid , the BACNET and modbus protocols are completely separate and do not share any information. It may be possible for a device to be configured with same ID numbers in both protocols but this would be 2 settings, device ID in Modbus and Device ID in BACNET.
Charles
Ramasamy_N
Ramasamy_N Champion
Champion
5202
Ramasamy N
diego.pedraza
diego.pedraza
Explorer
Posted: ‎2024-09-03 06:54 AM
Hello @Ramasamy_N
"The Modbus unit ID is fixed as 255 and it can be changed ..."
I have not found a way to change this, maybe you have a typo? you mean it cannot be changed?
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2024-09-24 08:38 AM
Hello @diego.pedraza
Sorry, it was typo error. The Modbus unit ID can not be changed in PM5340 meter, since it is standalone TCP device.
The meter which supports gateway feature can change the unit ID.
Ramasamy N
sesa29811
sesa29811 Contributor
Contributor
Posted: ‎2024-10-04 09:29 AM . Last Modified: ‎2024-10-04 09:30 AM
That makes sense its 255 since our IFE modules that talk to the breakers also use 255 as the default Modbus address and cannot be changed either
