Continue
  • My Subscriptions
  • Events
PM5000 Modbus/TCP
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM5000 Modbus/TCP
Charles_Murison
Charles_Murison Champion
581
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
EcoStruxure Panel Server
jedzruiz1985
jedzruiz1985
Explorer
Posted: ‎2024-07-22 12:18 AM
1472
PM5000 Modbus/TCP
Hi Team,
Just a question, what is the maximum number of Modbus/TCP (e.g. PM5320) meters can a PAS800L accept without compromising its performance?
Thanks in advance.
  • Thumbnail of EcoStruxure Panel Server
View products (1)
  • PM5000
Mehran_Mehrnia
Champion
Posted: ‎2024-07-23 05:05 PM
Hi @jedzruiz1985
You're welcome.
Using Modbus T tap-off might degrade the quality of the communication signal, cause delays in processing and limit the maximum number of TCP devices, but I cannot say for sure if such configuration would impact panel server and the maximum number of connected TCP devices.
Kindly post your question in Gateways and Energy Servers channel and Panel sever experts will assist you.
Thank you.
Best Regards,
-Mehran
L3 Expert tech Support Specialist
Mehran_Mehrnia
Champion
Posted: ‎2024-07-22 05:56 PM . Last Modified: ‎2024-07-22 05:58 PM
1
1433
Hi @jedzruiz1985
As mentioned in Panel Server User guide, section 'Maximum Configuration':
With fw 1.7 or later, PAS supports 128 TCP/IP device connections.
To receive better assistance and information, I would recommend posting the PAS related topics in Gateways and Energy Servers forum.
Thank you.
Best Regards,
-Mehran
jedzruiz1985
jedzruiz1985
Explorer
Posted: ‎2024-07-22 06:12 PM
Thanks for your response. Is this applicable if the pm5320 meters will be daisy chained using modbus T tap-off to the panel server? Will it still be 128 modbus/tcp devices or this configuration is applicable only using a switch?
Mehran_Mehrnia
Champion
Hi @jedzruiz1985
You're welcome.
Thank you.
Best Regards,
-Mehran
