PM 8000 set up issue
Metering & Power Quality
Send InviteCancel
Not enough information to say one way or another. Setting the nominal voltage setting should not reset the meter. It could be control power to the meter was removed, it could be meter had completely unrelated exception that caused meter to restart.
A quick starting point would be meter's event log, perhaps there are some clues there. If you need more in-depth investigation, you would likely need to start a support case with your local technical support.
