Continue
  • My Subscriptions
  • Events
PM 5330 Modbus RTU to Bacnet IP gateway
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM 5330 Modbus RTU to Bacnet IP gateway
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
PowerLogic PM5000 series
DickyGray
DickyGray
Explorer
Posted: ‎2022-10-24 05:36 AM . Last Modified: ‎2023-03-16 01:18 AM
2863
Hi all,
Couple of things,
Has anyone taken a Modbus rtu bus of PM5330's into a Modbus rtu to bacnet ip gateway ?
  • Are points auto transposed to bacnet objects, and little modbus config required ?
  • The naming all comes through intact ?
  • Changeover of values ( kilowatts to Megawatts ) requires no config
Thanks in advance,
Rich
  • Thumbnail of PowerLogic PM5000 series
View products (1)
  • ION Setup
  • PM5000
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2023-01-11 04:08 AM . Last Modified: ‎2023-01-11 04:09 AM
Hello GIA,
The gateway option in PM5563 supported only for Modbus protocol. We can not use as BACnet gateway.
However, the BMS controller like SE Automation server (https://www.se.com/in/en/download/document/03-14020-en/) supports the Modbus serial port to read the data from NSX Micrologic and PM5330 and view the data in the BMS system.
Ramasamy N
Replies 4
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2023-01-09 10:13 PM
Hello @DickyGray
Never tried to convert the PM5330 Modbus RTU to the BACnet IP objects, You can explore the gaetway manual.
However PM5340 supports BACnet IP protocol. The list of supported objects are listed in PM5300 user manual.
Ramasamy N
geir_eas_no_bfo
geir_eas_no_bfo
Troubleshooter
Posted: ‎2023-01-10 11:49 PM
2655
Schneider has limited productes for bacnet and reading NSX Micrologic.
Can we use a PM5563 as a Bacnet gateway for NSX devices connected with RS485?
BR
GIA
Ramasamy_N
Ramasamy_N Champion
Champion
Hello GIA,
Ramasamy N
geir_eas_no_bfo
geir_eas_no_bfo
Troubleshooter
Posted: ‎2023-01-11 04:18 AM
Hi, thanks for the clarifictation.
I will ask my SE-representative why this product is not supported in Norway.
BR
GIA
