Continue
  • My Subscriptions
  • Events
ION9000 boot problem
Metering & Power Quality
  • EcoStruxure Power & Grid
  • ION9000 boot problem
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
danielbarrantes
danielbarrantes
Troubleshooter
Posted: ‎2023-07-04 03:57 PM . Last Modified: ‎2023-07-04 03:59 PM
2171
Hi, I am trying to set up a new ION9000, however when I turn it on the rear "On/Off" LED just flashes green and red for hours. Checking the manual, it indicates that it is due to a boot sequence or in the process of updating firmware (which it can't be because I can't access the meter), however this "boot sequence" never ends.
The meter is an ION92030 and it doesn't have a screen so I can't configure or reset it. As it does not start correctly, it does not allow me to ping it, nor configure it through ION Setup or web server.
Do you have any recommendations for this specific case? @Charles_Murison @Attila_Fritz
Please see the attached video.
Attached support material.
Greetings
ION9000 Boot.mp4
Charles_Murison
Champion
Posted: ‎2023-07-04 10:06 PM
2167
Hello @danielbarrantes ,
Sad to sad that when the meter is in a boot error like this there is not much that can be done in the field. If you have checked the supply voltage is constant and not dropping when meter stars to draw current then meter will need to be returned for Repair. (RMA). To start the RMA process you will likely need to start a support case with tech support to get a case number.  se.com -> Support -> Contact support.
Charles
Charles_Murison
Champion
2167
Charles
MBw
MBw
Explorer
Posted: ‎2026-01-13 06:08 PM
546
Hello Charles, I have the exact same problem.
I reached out to Support but they are asking me to go through Distributor, which I don't have any for my purchase.
How can I get support to fix this meter? or replace it?
Please advise.
Charles_Murison
Champion
Posted: ‎2026-01-15 08:47 AM
Hello @MBw ,
Different countries and regions have different requirements on how to return a device. I am not sure that "go through Distributor" means you have to buy original meter from distributor. I suggest asking tech support for a list of distributors in your area then reaching out to distributor of your choice for steps to return the meter.
Charles
