Continue
  • My Subscriptions
  • Events
ION8800B ftp not allow to paste CID file
Metering & Power Quality
  • EcoStruxure Power & Grid
  • ION8800B ftp not allow to paste CID file
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Yut
Yut
Leader
Posted: ‎2019-11-27 01:30 AM
3339
I open the ftp:// but cannot paste CID file nor from CET850.
The firmware is V370 replaced by  V370_8800B_61850.upg I used the V362e templates because I could not find the V370e template. Any suggestion. I did 61850 with other meter before with ION8800 V362 it was OK.
Charles_Murison
Champion
Posted: ‎2019-11-28 09:34 AM
3329
Hello Yut,
Personally I find using Windows Explorer rather than Internet explorer easier to work with for FTP. The address bar would be the same: ftp://[ipaddress]
Charles_Murison
Champion
Posted: ‎2019-12-02 10:09 AM
3315
Hello Yut,
I would not recommend making changes to the IEC 61850 MMTR, MMXU etc as this could lead to confusion if someone assumes the meter is still in default configuration. Does the 8800 ICD file have GGIO Cust AI? This is where I would put the custom measurements. You are limited to 16 measurements.
Replies 12
Charles_Murison
Champion
Posted: ‎2019-11-27 04:47 PM
3337
Are you using addition 1 or 2? Can you attach your CID file?
Yut
Yut
Leader
Posted: ‎2019-11-27 07:49 PM
I redo from beginning using Edition 2 with the SE_ION_8800-B-Onb5-F01_E2V01.ICD.
Please see the CID file  Is there any security restriction on new ION8800 V370 ?
Yut
Yut
Leader
Posted: ‎2019-11-27 08:12 PM
3331
I can open FTP but cannot paste anything.
Charles_Murison
Champion
3329
Hello Yut,
Yut
Yut
Leader
Posted: ‎2019-11-28 04:54 PM
I try the Windows Explore too.
Wonder I used to do it before with the old firmware version.
Yut
Yut
Leader
Posted: ‎2019-11-28 08:44 PM
3325
I change the computer then install CET850 V3.1.2 everything is OK.
New computer is Windows 10 Pro the  old one using Windows 7 .
The error message showed
This site can’t be reached
The webpage at ftp://0:0@192.168.2.11/ might be temporarily down or it may have moved permanently to a new web address.
ERR_FTP_COMMAND_NOT_SUPPORTED
When use Windows Explorer it runs OK with new computer.
Thank you Charles
Yut
Yut
Leader
Posted: ‎2019-11-29 01:04 AM
3323
Finally I got it work when test with TriangleMircro tools. Next how to customize the measurement aside from factory default any advice please.
Charles_Murison
Champion
Posted: ‎2019-11-29 10:00 AM
3321
Not sure what customization you want to make.
Yut
Yut
Leader
Posted: ‎2019-12-01 11:34 PM
3318
For example we want to add value from store module that store end of month energy reading or daily kWh reading.
How about the IEC61850 modules each were set after the CID file has been loaded. If I edit the link will it be changed in
the CID file ?
Charles_Murison
Champion
3315
Hello Yut,
Yut
Yut
Leader
Posted: ‎2019-12-02 07:45 PM
That is great I will work on AI.
This is the first project of the Utility here in Thailand about IEC61850 our ION8800 was chosen to be the model for IEC61850 Learning Center I'd like to give them the best.
Yut
Yut
Leader
Posted: ‎2019-12-02 08:17 PM
I work with GGIO Cust AI try to add kWh del and kvarh del int  to Anln1 and Anln2 they work fine.
Thank you very much.
