Hi Comunity,
I have a small issue with Power total always 0, while the different Power By Phases are having reading,
Set made is
6000:5
kWa = 0.195 MW
kWb= 0.191 MW
kWc= 0.190 MW
kW tot = 0 MW
B.R.
Issue was solved by changing the
UseFundkVar to ON
Scale Rev Param to ON
Many thanks,
Hello @EA23 ,
Have you tried to paste the default template on the meter again?
Charles
Hello @EA23 ,
Likely there are other External Boolean modules that are typically on be default and currently off. I would strongly recommend, if possible, to re-apply the meter's template to ensure that all default external Boolean modules are turned on that should be on.
Charles
