Continue
  • My Subscriptions
  • Events
ION 7550 Readings
Metering & Power Quality
  • EcoStruxure Power & Grid
  • ION 7550 Readings
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
sesa286450_brid
sesa286450_brid Leader
Leader
Posted: ‎2015-05-04 09:22 AM . Last Modified: ‎2020-04-22 01:27 AM
1398
ION 7550 Readings
After installing an ION 7550 meter i have differnt reading on the PF parameter.
one phase of the meter is giving out a low power factor which is affecting the KILOWATT output from this phase and as well the total kilowatt output of the meter in general.
See attached the screen shots of the reading on the meter.
What could have caused this disparity in the readings. I have checked the installation and seems all is fine.
  • ION Setup
sesa130444_brid
sesa130444_brid Troubleshooter
Troubleshooter
Posted: ‎2015-05-04 10:56 AM
1352
Taye,
Can you provide a phasor diagram? The phase A negative kVAR while the other two phases are positive is an indication of some metering wiring issues.
Thanks.
Yut
Yut
Leader
Posted: ‎2016-01-14 10:21 PM
Is there any equipment connect between phase A and B such as under voltage relay or anything that has coil.
