Continue
  • My Subscriptions
  • Events
How to upgrade PM5320 firmware
Metering & Power Quality
  • EcoStruxure Power & Grid
  • How to upgrade PM5320 firmware
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
sesa97267_bridg
sesa97267_bridg Contributor
Contributor
Posted: ‎2016-01-20 07:28 AM
3906
I have a PM5320 with Firmware 1.3.7 and I would like to upgrade it to latest version available in Shopping Kiosk (1.5.0 = PM53XX_V01_05_0)
I can communicate with it and see it in ION set-up but I can not perform firmware upgrade.
In DLF3000, healthcheck always fails.
In ION Setup, firmware is requested to be a".fwb" file.
I do not have such files, only ".fw" are available.
I tried to rename to ".fwb" but the transfer fails anyway with the following message:
Can anyone give hints or guidance?
Regards
sesa97267_bridg
Contributor
Posted: ‎2016-04-07 12:39 AM
Support team could gave us the answer!
In attachment you'll find the procedure which explains how to force Modbus Slave Address to 255 in DLF-3000.
Additionally, f Health Check or Download keeps failing, try the following additional trick.
    • switch the PM to its default IP address (from front face interface)
    • change your computer IP address to a compatible IP range
    • perform the upgrade de procedure again
    • restore PM IP address
    • restore your computer IP address
Replies 4
Robert_Lee
Robert_Lee Champion
Champion
Posted: ‎2016-01-20 08:58 AM
3756
The FWB format is a new firmware file format in development for non-ION based products such that we can use a singular software platform (ION Setup) to perform device upgrades.  Unfortunately not all devices have been able to transition to this new file format yet so most products do not yet support the file format and will be slowly moving to support the FWB.  For products which still have the FW format, the DLF-3000 software tool still is the only means to get that firmware on the device.
If DLF-3000 is giving errors, you will need to contact Tech support and provide and details along with what device type you are selecting when performing the upgrade and details on what error messages you are receiving.
sesa97267_bridg
Contributor
Posted: ‎2016-01-20 09:15 AM
Hi Robert,
thanks for your answer, very clear now that I should not keep trying performing this with ION Setup.
I'll keep exploring the DLF-3000 option with tech support,
Regards
sesa97267_bridg
Contributor
Sven_Ortmann
Sven_Ortmann Leader
Leader
Posted: ‎2018-08-29 09:07 AM
where do I find the download of newest Firmware from PM5320 Meter?
V2.1.1 newest Version?
Thank you
