How to change PM8xx data log file mode
Metering & Power Quality
  • EcoStruxure Power & Grid
  • How to change PM8xx data log file mode
Charles_Murison
Picard Charles_Murison Picard
529
Mehran_Mehrnia
Admiral Mehran_Mehrnia Admiral
139
Ramasamy_N
Captain Ramasamy_N Captain
115
Robert_Lee
Admiral Robert_Lee Admiral
Admiral
Posted: ‎2014-01-29 12:32 PM . Last Modified: ‎2020-04-22 01:52 AM
The default setup file doesn't support the modification of the data log file mode but this functionality can be manually added to the file using the following steps.
Using Windows Explorer, locate the ION Setup program folder (typically C:\Program Files\Schneider Electric) and go into the TABLES sub-folder.
Next, go into the folder for the model you wish to add the file mode to (ex. PM820).  In that folder, you will find a SETUP.CFG file which you should open using a text editor such as Notepad.
Locate the section for the log you wish to add.  Below is the section for Data Log #1 for the PM820.
[Data Log #1]
FeatureMask=0x00010000
SetupNum=3
SetupType=1
StartAddress=47002,47012
Registers=4,4
Setup1=1,7,Status
List1=0=Disable,2730=Auto-Enable,65535=Enable
Setup2=3,32,Interval
Limit2=0,1440
Setup3=7,24,Channels
ChannelOffset=3
TotalFileSize=7404
FileInfo=1,32700
Increase the SetupNum by 1 (In the above example, this is done by modifying the line SetupNum=3 to SetupNum=4).
We'll insert the FileMode after the Interval, so we need to add the following line above the Setup3 line and change that line to read Setup4 instead.
Setup3=2,7,File Mode
List3=0=FIFO,1=Fill and Hold
Setup4=7,24,Channels
The section should now look similar to the following:
[Data Log #1]
SetupNum=4
SetupType=1
Registers=4,4
Setup1=1,7,Status
Limit2=0,1440
ChannelOffset=3
TotalFileSize=7404
FileInfo=1,32700
Save the file and reopen the Data Log setup screen in ION Setup and the File Mode will now be displayed and can be changed if desired to do so.
  • ION Setup
Replies 0
