Continue
  • My Subscriptions
  • Events
How does the ION meter keep time when the power is off?
Metering & Power Quality
  • EcoStruxure Power & Grid
  • How does the ION meter keep time when the power is off?
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
T.Okada
T.Okada
Contributor
Posted: ‎2021-12-14 03:04 AM
2222
Hi support,
Our customer asked me " How does the ION meter keep time when the power is off? "
and "Is it possible to replace the battery if the ION meter keeps time using something like coin battery?"
if so, how often do they have to replace it?
Do you have any idea?
Okada
Charles_Murison
Champion
Posted: ‎2021-12-14 10:10 AM
2214
Hello @T.Okada ,
I moved your question to the metering forum. For the first question "How does the ION meter keep time when the power is off?" This is done with a battery that is used to power the meter's clock.
As for your next question, there are some details missing such as what type and version of ION Meter.
For example, ION7650 meters have 2 different versions, the most common is the Comm Card has a socket where a battery can be placed. See https://www.se.com/in/en/faqs/FA411084/ for more details.
ION8650 meters have a detachable battery that can be replaced. See here
Charles
Replies 6
Charles_Murison
Champion
2214
Hello @T.Okada ,
Charles
T.Okada
T.Okada
Contributor
Posted: ‎2021-12-14 04:13 PM
2207
Hi Charles,
Thank you for answering my question quickly!
and sorry for lack of meter type information.
In this case, our customer uses METSEION92040 and METSEPM8240.
Would you please tell me about these models?
Okada
Charles_Murison
Champion
Posted: ‎2021-12-14 04:47 PM . Last Modified: ‎2021-12-15 10:24 AM
2205
Hello @T.Okada ,
The ION9000 and PM8000 meters have a battery with expected lifespan of at least 7 years. The battery replacement kit has not yet been commercialized.
Charles
T.Okada
T.Okada
Contributor
Posted: ‎2021-12-14 05:35 PM
Hi Charles,
Thank you for your support.
I understand about the battery of ION9000 and PM8240.
Best regards,
Okada
galcaPsE
galcaPsE
Explorer
Posted: ‎2023-01-31 05:58 PM
1891
Hello @Charles_Murison and @T.Okada,
I had an event where an ION8650A was turned off for 2 hours, then turned on and the clock was 4 minutes lag. It currently has a remaining battery percentage of 70% and the battery was replaced 6 years ago.
When the battery is new should theoretically keep time?
Is it time to change the internal battery?
I will appreciate your clarification,
Gustavo
Charles_Murison
Champion
Posted: ‎2023-02-01 08:38 AM
Hello @galcaPsE ,
When the battery was replaced, were the counters reset to return to 100%? Not enough information to go on clock. Recommend you contact your local technical support and collect diagnostic information.
Charles
