Continue
  • My Subscriptions
  • Events
【HDPM6000R】Regarding sampling rate
Metering & Power Quality
  • EcoStruxure Power & Grid
  • 【HDPM6000R】Regarding sampling rate
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Miyai
Miyai
Contributor
Posted: ‎2025-01-28 09:26 PM
1234
I would like some advice on why there are two sampling rates.
The HDPM6000 “installation guide” states the sampling rate is 160.
However, the “data sheet” states the sampling rate is 128.
Why are the sampling rates listed differently?
Miyai
  • HDPM6000
Mehran_Mehrnia
Champion
Posted: ‎2025-01-30 07:31 AM
Hi @Miyai
The HDPM meters all sample at 8000 samples per second, which works out to be 160 samples per cycle at 50Hz, and 133.3 samples per cycle at 60Hz. The table from the HDPM6000 Installation guide is correct.
Best Regards,
-Mehran
L3 Expert Advanced metering
Mehran_Mehrnia
Champion
Posted: ‎2025-01-29 08:41 AM . Last Modified: ‎2025-01-29 08:41 AM
1212
Hi @Miyai
If you check the latest edition of both HDPM6000 Installation guide and HDPM6000 Data sheet, you will find the same rate of 160 samples/cycle:
Data sheet:
Installation guide:
Best Regards,
-Mehran
Miyai
Miyai
Contributor
Posted: ‎2025-01-29 04:13 PM
Hi @Mehran_Mehrnia
Sampling rate of HDPM6000R unit is 128 cycles.
Is this information correct?
https://www.se.com/us/en/product/download-pdf/METSEHDPM6R42?filename=Schneider+Electric_PowerLogic-H...
The documentation for the HDPM6000 head unit states that the HDPM6000R has a 160 cycle rate.
I would like to know what is correct.
Miyai
Mehran_Mehrnia
Champion
Hi @Miyai
Best Regards,
-Mehran
