Continue
  • My Subscriptions
  • Events
Firmware on ION7350 Ethernet
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Firmware on ION7350 Ethernet
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
jlin_dvlnet_com
jlin_dvlnet_com
Contributor
Posted: ‎2017-07-26 08:28 AM
1378
Is it possible to flash an ethernet ION7350 with non-ethernet firmware such that it opens COM2 for any protocol (rather than being limited to ethergate)?  We are not using the ethernet port at all.
Jason
Tags (2)
  • firmware
  • ion7350
jlin_dvlnet_com
jlin_dvlnet_com
Contributor
Posted: ‎2017-07-26 08:47 AM
Tech support notified me that the ethernet port is hard-coded into the meter, so this is not an option.
The alternative is to use an ethernet-to-serial gateway.
jlin_dvlnet_com
jlin_dvlnet_com
Contributor
