Continue
  • My Subscriptions
  • Events
Do we have a Direct Current Energy Meter in our offer?
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Do we have a Direct Current Energy Meter in our offer?
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Bojan
Bojan Leader
Leader
Posted: ‎2014-09-18 08:49 AM
12
4739
Tags (4)
  • current
  • direct
  • energy
  • meter
VictorMarincus
VictorMarincus Champion
Champion
Posted: ‎2014-09-19 06:47 AM
Hello Bojan,
As far as I know we don't have DC power and/or energy meters in our offer.
Replies 12
Abdel
Abdel Troubleshooter
Troubleshooter
Posted: ‎2014-09-18 03:04 PM
Hi
Yes IEM31xx
LaurentCoene
LaurentCoene Leader
Leader
Posted: ‎2014-09-18 07:06 PM
5
4609
Just to add to 's answer. The iEM31xx will work up to 63A.
If you need to go higher, use the iEM33xx which goes up to 125A.
Good luck!
Bojan
Bojan Leader
Leader
Posted: ‎2014-09-19 06:07 AM
4610
Thanks for the suggestion, but it must be my ambiguous question - in the Schneider Electric iEM31xx / 32xx series Energy Meters User manual DOCA0005EN-02 06/2013 there is no wiring for measuring DC Energy, only 3PH4W, 1PH2W L-N, 1PH2W L-L, 1PH3W L-L-N and 3PH3W.
http://www.schneider-electric.com/download/ww/en/details/126676969-iEM3100-series--iEM3200-series---...
My client asked me for a meter which could measure electrical energy on UPS DC side, so he can compare it with a measurements on AC side and calculate an efficiency of it.
Best Regards,
Bojan
VictorMarincus
Champion
Hello Bojan,
Abdel
Troubleshooter
Posted: ‎2014-09-19 06:54 AM
Hi Bojan,
sorry, for me i thought you mean the Opposite of not Direct (With CT).
Have a nice weekend
Kevin_Morin
Kevin_Morin Mentor
Mentor
Posted: ‎2014-09-29 12:40 PM
2
4610
you might consider suggesting they use a 4-20mA CT (suitable for direct current) and route the signal to an analog input (assuming they are using something like a ION7X50 for the UPS Input).
They might check with the UPS vendor as well, it's possible you can read the DC output register via coms?
Good luck.
Critical Power EcoXpert Program Director
arjanbijker
arjanbijker Leader
Leader
Posted: ‎2014-09-30 03:21 AM
2
4610
We had to use DC Shunts to get a mV output.  One of our SIs developed a Modbus card which gives the DC Voltage and Current inputs.
Bojan
Bojan Leader
Leader
Posted: ‎2014-09-30 05:47 AM
4610
What is an accuracy of energy measurements for the card?
Bojan
Bojan Leader
Leader
Posted: ‎2014-09-30 05:51 AM
4610
Hi Kevin,
I suppose it must be a some kind of Hall effect IC sensor, as transformer is suitable for AC current only.
KuanKhoon
KuanKhoon Mentor
Mentor
Posted: ‎2014-09-30 06:12 AM
Hi Bojan,
You can look at a special product from Veris Industries, also wholly-owned subsidiary of Schneider Electric, to monitor solar PV installation at the DC output from individual solar panels,
http://www.sunspec.org/wp-content/uploads/2012/06/Veris-EA10-article-for-SunSpec.pdf
http://www.veris.com/docs/comms/mb_pmap/EA10_pm_06121.pdf
The only drawback I think would be that it starts with 8 channels, but if you require multiple channel monitoring, it can freely scale in units of 8 up to 32 channels.
Cheers!
arjanbijker
arjanbijker Leader
Leader
Posted: ‎2014-09-30 06:56 AM
5% accurate
Sent from my iPad
Kevin_Morin
Kevin_Morin Mentor
Mentor
Posted: ‎2014-09-30 08:01 AM
yes, exactly.
